Officially it is a DFW (Don't F#@& With), set at the factory. What is it currently set for? I have had occasion to remove a doctor blade to remove foreign material from behind it. I and seem to recall measuring it before removal and using a 0.45mm feeler to reset it, but I can't promise you that is correct as it was some time ago.
Thanks Zed, I've seen it on some other posts on the web that it should be .45mm.
I was still getting somewhat ghost image but checked settings, set some of those in 2xxx zone for default, and ran about 25 sky shots - all's fine after 600 copies.
