savin 2575 sc440 help
  • apcrap
    • Jun 2010
    • 25
    working on a savin 2575 with a sc440 code . I checked the drum assy , transfer unit and everything spins smooth . All 3 paper drawers wont lift , checked all fuses on power supply and checked main motor in i/o mode just codes out . Im going to see if im getting 24v at the main motor . has anyone had this problem??????????????/
  • apcrap
    • Jun 2010
    • 25
    i replaced the power supply it fixed the problem
    • z_ming
      • Jul 2011
      • 31
      Re: savin 2575 sc440 help
      i have same problem on ricoh aficio 1060 . i 've tried replace drive broad ,main motor , paper tray control broad . nothing
      happens .
      • m_donakov
        • 213
        Same problem on 1075 Ricoh little bit old post but please help
        regards
        Mile
          • 37532
          Check the waste toner transport for the transfer belt unit. It is driven off the main motor. If it becomes clogged, it will cause a main motor lock error. Check the rest of the waste toner system as a backup going into the waste toner bottle can cause the transport tube to clog.
