this machine is jamming at fuser inlet andd the paper is wrinkled on the reg roller. fuser looks like new and just replaced the reg roller. could a sensor be bad? thanx
aficio 1022 jamming at fuser entrance
Check your registration clutch..... if the paper is wrinkling at the reg roller then it sounds like your not getting enough bite on the paper as it comes up to the reg area causing wrinkling.... also check your relay and feed clutches and also the press roller.Comment
If your wrinkling at the reg roller, check that the black guide is still in place when you open the right lower cover. They have a tendency to be pulled out of place when the customer is removing a misfeed.NEVER ASSUME ANYTHINGComment
Check the paperguide which the paper passes at the entrance of the fuser, probably you will find toner and papersmudge .Paper gets stuck to this rim of dirt....
Just clean it with a sharp knife or replace the entranceguide.technicians are the only ones that don't trust technical stuff !Comment
