How to set user code for af3025
Posts
  • kkwong0209
    • 45
    Hi,
    How to set the user code for af3025. Its seem a bit difference from af2027. Pls help.. thanks.
  • brouwer
    The first part:
    You can skip some of the options below, depending on whether you are changing details of a Destination or a User
    You can change as few or as many details as required
    Follow these steps:
    1. Press the [User Tools/Counter] key
    2. Touch[System Settings]
    3. Touch the [Key Operator Tools] tab then touch [Next] to view the second page of this menu
    4. Touch the [Address Book Management] key then touch the User/Destination key that you want to change ( see below for tips on how to search for these keys)
    5. View the menu and :
    • brouwer
      2nd part:
      touch [Change] and use the [Backspace] or [Delete All] key on the display keypad to remove the existing name
      key in a new name then touch [OK]
      the User (Destination) Name box will now show the new name
      do the same to change the name of the title that you want to appear on the Key Display ( if you decide to skip this step, the User (Destination) Name will appear here by default)
      select the Title Key - your user/destination will be stored under the selected title letter or number
      <br/ >
      1. Touch[Fax Dest.] then:
        • touch the [Change] key
      • brouwer
        3rd part:
        use the [Backspace] or [Delete All] key to remove the existing fax number then enter a new number from the blue numeric keypad
        touch the [OK] key located next to the [Delete All] key (not the [OK] key at bottom right of the menu)
        switch the International TX Mode by touching its associated [Change] key, selecting [ON] or [OFF], then touching [OK]
        change the Fax Header by touching its associated [Change] key, selecting one of your pre-programmed headers, then touching [OK]
        switch Label Insertion (not shown) On or Off
        <br/ >
        Touch[User Code] if you have enabled User Code Management and want to change the 8-digit code that the new user must enter before operating the machine:
        • touch the [Change] key and enter a new 8-digit code from the blue numeric keypad
        • touch the Hash key (#) then touch to highlight the functions whose access that you want to restrict with the User Code<br/ >
        • brouwer
          4th and last part:
          1. Touch[E-mail] if the User or Destination also has an email address:
          2. touch the [Change] key and use the [Backspace] or [Delete All] key on the display keypad to remove the existing email address
          • enter a valid email address from the display keypad and touch [OK] to finish
          • set the remaining email options as required <br/ >
          1. Touch [OK] and [Exit] to complete the operation
          <br/ >
          1. Press the [User Tools/Counter] key to exit from the User Tools menu
          <br/ >
          1. If displayed, touch [Exit] at the dialog box which alerts you that the Destination List is updated
