Limiting colour on MPc3001
  • Gesttech
    • Oct 2009
    • 123
    Hi
    I have a client who wanted to limit colour for her user. I seach on driver but only PcL6 & 5 are available. Can not limiting colour for MPC3001 . For me I know on Mpc3000 there are driver RCPS that can limiting colour. Are driver RCPS compatible with MPc3001.
    Thanks.................
  • Gift
    • Mar 2011
    • 2459
    RPCS drivers are (officially) nor more longer developed/supported for new machines and generally "discontinued". Therefore Ricoh put more efforts in the PCL6 driver to improve the feautures/usability.
    An easy way to monitor the color printing behaviour of different users/departments is to work with unique account numbers/(software)key counters wich can be done "out of the box".
    Unfortunately I don't know how to set up some kind of color contingent to make it impossible to print more than xx pager per day/week/month/whatever...
    • SGT_Snacks-64
      • Oct 2007
      • 157
      The RPCS Driver isn't available for the MPC3001. I believe it's not supported anymore.
      You can achieve what your client wants with the PCL5/6 Driver.
      Create a User Code on the machine in question. Limiting Printing to Black and White only. Enable User Access Control (I haven't worked on Ricoh devices for a couple of months now, so I can't remember if it's PC:CONTROL you select or not, you'll have to experiment) You can then enter this code on the Driver for users who should not print Colour (In properties, there's a User Code tab, you'll want to enter this on "Printing Preferences" and "Printing Defaults".
      Sorry I can't clarify more, I hope I've given a brief explanation on what needs to be done. Maybe someone could expand on this?
      Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
      Asus P5E-VM HDMI
      4GB (2x 2GB) Corsair XMS Xpert II RAM
      ATi Radeon 4870 512MB GFX Card
      2x 74GB WD Raptor Sata HDD (RAID 0)
      500GB Seagate Barracuda Sata II HDD
      500GB Hitachi Sata II HDD
      600W500att OCZ PSU
      -TOTAL HDD SPACE 1148GB-
      • SGT_Snacks-64
        • Oct 2007
        • 157
        As far as I know, you can't limit to a specific amount, you can only enable or block Colour printing for specific users.
        Asus P5E-VM HDMI
        600W500att OCZ PSU
        • rthonpm
          • Aug 2007
          • 2859
          Some of the newer machines have a Java app that can limit the number of pages a user can print in colour or in general. You may want to look to see if that's available for this model.
          • rsyarcia
            Hair Straightener Tech
            • 711
            user quota can now be set with this model(job limits and page limits). if you want to restrict the color printing then set it in the user authenitcation management and address book
            Nobody is perfect..
            • rsyarcia
              • 711
              color restriction can be done also in pcl 6
              Nobody is perfect..
              • techsass
                • Dec 2010
                • 248
                You can use the Print Editor. I've only used it to create popup windows for users to enter user codes, but you can use it to block color printing.
                just a note - I've only got it to work on the PCL5 on the latest drivers.
