Screen wording problem on MP6001
  • Gesttech
    • Oct 2009
    • 123
    Hi
    I have problem with MP6001 Screen. On screen it display 'A4 like [] '& some white line on right. On SP mode can not see nothing, word are illegibile. I replaced the LCD Screen, problem still remain. What to do? Now I order the LCD screen main Board. Help Me Please
    Thanks...............
  • Jomama46
    • 2900
    Re flash the firmware. Include the language.
    sigpic
    A+; Network +; PDI+
    • Gesttech
      • Oct 2009
      • 123
      Hi Jomama46
      I Tried to flash the firmware & language. Before i began, i copy the firmware to an Sd card 32mb on a create 'ROM' folder on pc. Then i switch off the copier machine, enter the sd card to slot 2 in copier machine. Switch on the copier machine here nothing happen no display of update only Please wait then the normal display Ready began. What to do?
      • rthonpm
        • Aug 2007
        • 2859
        Name the folder on the SD card romdata, then in that place another folder with the build number for the machine (the D number in this case) then place the firmware in that folder. You might as well re-flash or update everything as up to date firmware is always a good thing.
        • tcs04
          FORMER Techie
          • 1183
          and be sure the SD card isn't locked.
