savin 9965 w-542
  • T911
    • Jun 2007
    • 628
    savin 9965 w-542
    can't get rid of this one. initially the sr730 wasn't powered up but the machine worked. went back with main pcb for the sr730 and it came back. now the copier will not come to ready. the fuser lamps do not come on. I went back with the i/o interface bd and lvps and still doesn't come to ready 542 still. help appreciated t
  • TonerMunkeh
    Professional Moron
    • 3865
    Stats and thermistors okay?
    Hit it.
    • T911
      • Jun 2007
      • 628
      all good.
      • TonerMunkeh
        Professional Moron
        • 3865
        Bit of an odd one. By I/O board do you mean BICU?
        Hit it.
        • T911
          • Jun 2007
          • 628
          Input/output
          • Ricohtechguy
            • Apr 2011
            • 11
            Pull the fuser unit out of the machine and check the lamp wires in the back of the fuser. Make sure they did not get caught in the drive gear. I have to ask but did you clear the fuser fault by going into service and them shuting the machine off while it is in service to clear the fault. I have had the gears and the drive coupling cut the lamp wire. This also blew out the BICU board and the lvps.
            • TonerMunkeh
              Professional Moron
              • 3865
              Christ it's been that long since I've seen one of these buggers I can't remember much about them. I'd go with the BICU board for a start, got a spare laying around?
              Hit it.
              • T911
                • Jun 2007
                • 628
                i'll go back with another bicu and fuser unit just in case. thanks t
