3025 Vsp/Vsg/Vsdp/Vt/Vts values are correct?
  • ponto700
    • 144
    Hi to all,
    today i rebuild one pcu of 3025 (developer, drum, c.blade) and the counter print is excelent. but when i make one copy looks like the density is lower. i already force tonner, clean all mirrors but the result is the same.
    here are the values:
    vsp - 0.78
    vsg - 3.66
    vsdp - 3.78
    vt - 1.82
    vts - 2.09
    are this values correct? or something is not good?
    thanks in advance
  • TonerMunkeh
    Professional Moron
    • 3865
    Can you not just fit a complete PCU type 1027 and switch SP5-912 on? Saves a lot of cocking about with the Russian.
    Hit it.
    • ponto700
      • 144
      believe that is much easier... but i do my work according with client. he dont want to pay for a new unit thats why i rebuild it.
      • teebee1234
        • Jul 2008
        • 1670
        If the counter prints are good then the issue is with the scanner. If you cleaned the mirrors of any filming and the transfer roller is clean/new, check the settings. Are you copying in text mode or text/photo? Try setting it to Text mode with Auto Image Density off and see if that improves it.
        • ponto700
          • 144
          teebee1234,
          i have try that but i still have the same result. the transfer, mirrors all cleaned. i try to copy in text mode and photo mode but still have the same problem.
          regards.
