Not Accepting IP address
  • countrytech
    • Mar 2009
    • 68
    I have a Lanier/Ricoh MPC 2050 that appears not to be accepting the IP settings. I can enter the settings, and they show on the display, and on the config page, but do not show on the network settings print out, which remains as 11.22.33.44 I have reset the NCS, and started again, with no change. I can ping to 11.22.33.44 from my laptop and get a reply. Could this be a NV ram fault, or is there another answer. The problem only appeared after the customer changed the modem. I was using a cross over cable direct from the laptop, to isolate their network, but no change.
    Thanks.
  • Jomama46
    • 2900
    You have to first set the IP to fixed, not DHCP, OK that, then secondly change the IP address. OK that one.
    sigpic
    A+; Network +; PDI+
    • countrytech
      • Mar 2009
      • 68
      Yes I have done that, but makes no difference.
      • RRodgers
        • Jun 2009
        • 1947
        How are you turning it off? Button on top or switch on the side? I would only use the switch.
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          do the button then when it quits blinking do the switch. Been burned too many times buy customers improper shut downs. Back up the NVram and do 5801-1 and try it, if it doesn't work you can restore the NVram. If it works re enter all the non default data form the BC or print the non default data and config page before you begin.
          Mystic Crystal Revelations
          • tcs04
            FORMER Techie
            • 1183
            Try changing the settings with no network cable plugged in. Let the machine enable the settings, then connect. The are numerous firmware updates for this model relating to network / printing / power issues, I would make sure ALL firmware is up to date.
            • iMind
              Vacuum Cleaning Expert
              • Mar 2008
              • 1116
              Cross cable the thing; access via browser; login as ADMIN goto security settings and check if there are any certificates, if so delete them, also check if the IT guys limited the IP range there are four setting that can be setup to limit access to the machine; if so type in 000.000.000.000 and then apply. It would be helpfull to us if you could post a config page. Good luck.
              • countrytech
                • Mar 2009
                • 68
                Sorry for the lack of response, but the machine is in a remote area, and I don't have ready access. Have tried to clear the NV ram 5801-1 and 5801-11 but made no difference. I shall try the latest posts, and also post a config page. Hopefully should be in that area this week. Thanks for your support, I have installed a loan till sorted out.
                • mrwho
                  Major Asshole!
                  • 4299
                  Sorry if what I'm about to say sounds basic, but this happened to some of my colleagues:
                  Following Jomama's post, you need to use the OK key three times.
                  So:
                  - Set it to Fixed IP
                  - OK
                  - Press the IP Address key
                  - Set the IP Address
                  - OK
                  - OK Again
                  This last OK is what saves the whole thing onto the NVRAM. If you press the Back key, the machine will not memorize your IP address.
                  Mascan42
                  Ibid
                  • countrytech
                    • Mar 2009
                    • 68
                    I don't mind the basic, as sometimes that is what is overlooked.
                    • CSI
                      • Oct 2008
                      • 73
                      Look at the post of Choro1dal : http://www.copytechnet.com/forums/co...-question.html
                      • ChunkyOne
                        • Apr 2022
                        • 2
                        Re: Not Accepting IP address
                        I've had the same issue with my Ricoh mpc5501 and have resolved it.
                        I simply formatted the HDD drive using engineers code 5837#
                        The printer then took and retained the inputted static IP address
                        • sandmanmac
                          • 3990
                          Great!.....We'll be sure to load that into the time machine and send it back to 12 years ago when this thread was started!
