Ricoh 2025d..how do you make quick dials
  • landspeeder
    • Feb 2010
    • 355
    I looked thru the operators manual and cant find how to do a quick dial...I have a machine on demo and when I can do this feature they will buy it!!! Any detailed info would be great!!
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • TonerMunkeh
    Professional Moron
    • 3865
    Fax speed dials? Put an entry in the address book and program the quick press destination keys on the left (01, 02, 03 etc)
    Hit it.
    • landspeeder
      • Feb 2010
      • 355
      where is the address book and is that on the machine and do you have to use a computer?
      • nmfaxman
        • 1702
        Programming Fax Number and E-mail
        Addresses
        You can program fax destinations using Address Book Management in the Key
        Operator Tools menu under System Settings.
        You can also register the programmed fax numbers and e-mail addresses in a
        Group.
        Note
        ❒ When you press the {Facsimile} key after changing the contents of the Address
        Book, such a message appears that indicates that the destination list has
        been updated. Press [Exit]. The standby display appears.
        Reference
        “Key Operator Tools”, General Settings Guide
        “E-mail Destination”, General Settings Guide
        “Registering Destinations to a Group”, General Settings Guide
        Key Operator Tools (See p.57 “Key Operator Tools”.)
        Administrator tools
        Address Book Management --
        Address Book: Program/Change/Delete Group --
        Address Book: Program/Change/Delete Transfer Request --
        Address Book: Change Order --
        Address Book: Edit Title --
        Address Book: Select Title Title 1
