ricoh cl 7000, poor shine
  • DINGO
    • 661
    Hi
    i have a problem whith a ricoh cl 7000, because de copys had poor shine.
    I chek, if i take a copy in mode gross paper, using a normal papel the copi is very good, but in normal mode is sto poor.
    i`m thinking if i rise a litle the fuser temp in normal mode, may be the copy stay better?
    i need your help, and opinion, and if possible as i can rise a litle the temp.
    thank in advnace
  • Zeldaman
    • Mar 2011
    • 946
    Hi there!
    Check the "User settins", "Maintenance" there must be the option to change the paper-type of the cassettes. This may help.
    Greetings...
    • DINGO
      • 661
      ok
      i will chek, but if it`s like print interface, only in bypass is avaiable gross paper.
      thanks a lot
      • rthonpm
        • Aug 2007
        • 2854
        Check your fuser. Sounds like the oil is low or the unit needs replacing.
        • DINGO
          • 661
          hi
          first, thanks
          In the user settings i do not have that option, and the unit seems good,, ok .
          regards
