Anyone know why we are getting a sc542 code on startup after the machine has been off for a while? Once the code is reset, the machine runs fine for the rest of the day. We have had this problem on a couple different machines. If we replace the fuser this usually cures the problem, but as you know these fusers are very expensive! So whats the root problem?? Why only on cold startup?? Victor
B180 Ricoh 3245c sc542
SC542 occurs for other reason than faulty fusing unit
Details
[Symptom]
SC542 (Fusing unit 1 does not reload) occurs sometimes.
[Symptom Addendum]
It occurs when the power is turned on and the fusing unit is cold. If the fusing unit is warm, it does not occur.
Answer
[Cause]
The fusing drive clutch is faulty.
[Resolution]
Replace the fusing drive clutch.Comment
You should also check the fuser lamps, especially the one within the press roller. It's also a common issue that there is paper stucked in the fuser connector that can lead to different sorts of fuser SCs (happens if the customer overlooked a page behind the fuser unit during jam removal).
The fuser unit isn't thar pricey if you use a PM kit plus a fuser belt thermistor (it's not a part of the kit but you should change it if you rebuild/PM a fuser - this thermistor is kind of a metal plate with the thermistor element glued on it and over time the glue gets weak so the element becomes loosen from the plate what causes no SC but wrong readings and too much fuser belt temperature so the belt gets damaged - looks kind of wrinkled then).Comment
Thanks Gift, but I do know enough to check for paper between fuser connectors. Plus after 20 years fixing copiers, I damn well better know what a thermistor is haha... I was looking for something a little more technical.
Pulled out and cleaned the fuser clutch out today... oh yeah that was almost as fun as replacing the seperation roller drive gear in tray 1... ouch!! hope it works!!Comment
