sc 402 in af1045
  • iust
    • Jul 2008
    • 58
    sc 402 in af1045
    hi
    my af 1045 give sc402 . I check transfer conection and change this unit and check wire and bord but has not result. what do i do? (reset or firmware solve this problem?)
  • TonerMunkeh
    Professional Moron
    • 3865
    Change the transfer belt contact clutch.
    Hit it.
    • Jomama46
      • 2900
      x2 on the clutch
      sigpic
      A+; Network +; PDI+
      • iust
        • Jul 2008
        • 58
        Originally posted by Jomama46
        x2 on the clutch
        what is your Purpose "X2" ?
        cluche is a component of transfer unit. I change this unit Completely.but it has not result
        • Jomama46
          • 2900
          cluche is not a component on the transfer unit. It operates the up/down movement of the transfer unit and is accessible from the rear of the machine.
          sigpic
          A+; Network +; PDI+
          • Jomama46
            • 2900
            x2 on the clutch
            x2 means I agree with the assessment. I also think it is the clutch. (X2 = Times two)
            sigpic
            A+; Network +; PDI+
            • iust
              • Jul 2008
              • 58
              thanks you I check it
              • iust
                • Jul 2008
                • 58
                thanks a lot . I fixed it.
