Ricoh 3045 light copy only strip of the page
  • Ricoh Dicoh
    • Dec 2010
    • 62
    There is a consistent strip where the copy is light. The rest of the copy is dark.
  • tonnerboy
    • May 2011
    • 212
    Only in copy? what about print?
    • rsyarcia
      Hair Straightener Tech
      • 711
      have you cleaned the slit glass and laser unit?
      Nobody is perfect..
      • Jomama46
        • 2900
        x2 on the slit glass
        sigpic
        A+; Network +; PDI+
        • jonhiker
          • 661
          have you cleaned the toner shield glass?
          • Masterchief
            • Apr 2011
            • 280
            have you cleaned the mag roller on the development unit
            sigpic
            • rthonpm
              • Aug 2007
              • 2859
              Also check the top cover of the dev unit, the seal against the mag roller gets worn over time and starts scraping developer off the mag roller causing all kinds of strange light areas. There was a bulletin about this posted for the MP 4500.
              • cobiray
                Passing Duplication Xpert
                • Mar 2008
                • 1199
                If it is the laser filter glass, also make sure your dev filter is seated properly and not blowing out onto the slit glass.
