Gestetner DSm620d - no print functions?
  • chsearch
    • May 2011
    • 9
    I'm working on a gestetner machine - model DSm620d and all of the print functions seem to be disabled or missing. The same goes for the network settings. From all the documentation I've seen, there should be an Interface Settings submenu under the System Settings menu. But it's no where to be found.
    Any ideas?
  • rthonpm
    • Aug 2007
    • 2859
    Does the machine have a print controller installed? Is the SD in the right slot, or seated correctly?
    • rsyarcia
      Hair Straightener Tech
      • 711
      feature expansion board type 2018 and printer/scanner unit type 2018 should be there
      Nobody is perfect..
      • chsearch
        • May 2011
        • 9
        It looks like there is no print controller. I (incorrectly) assumed it had one.
        Any idea what that would cost to add on? From what you all have sent, it looks like it'll need the controller card in the back and either a new keypad or the additional buttons that are missing from the control panel. This one just has buttons for copy and fax on it.
        • iMind
          Vacuum Cleaning Expert
          • Mar 2008
          • 1116
          a price of a same copier, 2nd hand with all options installed.
