Ricoh Pro550ex with Fiery E-8100 SC919 and SC991
  • mguarderas
    • Jul 2025
    Hi,
    Need help on trying to resolve an issue with a Ricoh Pro550ex and the fiery attached to it.
    Every morning the machine has SC 919 code and a SC 991 code all you have to do is reboot both device and it works for the rest of the day.
    I have replaced the giga cable from machine to fiery. replaced the gig card on the machine.
    updated firmware. reloaded fiery system software. any help would be appreciated. Thank you
  • JustManuals
    • Jan 2006
    • 9838
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      Found this in the global knowledgebase:
      IMPORTANT NOTICE:
      If the EFI Fiery controller E-7100/E-8100 is connected to customer's machine, DO NOT update to the versions of firmware listed below until a corresponding new version of system software is installed on E-7100/E-8100. The new version system for E-7100/E-8100 that supports the Ring Binder RB5000 will be announced later in a separate TSB.
      Note: the Pro C550EX (D078) and Pro C700EX (D079) come with the E-8100 installed in the American Market
      Firmware for
      D014/D015/D078/D079 copier
      Version
      Program No.
      System/Copy
      1.09 or newer
      D0145761K or newer
      Remote Fax
      03.00.00 or newer
      D0145768C or newer
      Web Uapl
      1.07 or newer
      D0145770D or newer
      Web Support
      1.31 or newer
      D0145769G or newer
      Network DocBox
      2.02 or newer
      D0145771E or newer
      Fax
      04.00.00 or newer
      D0145773D or newer
      Printer
      1.09 or newer
      D3765902F or newer
      Scanner
      01.07 or newer
      D3765903D or newer
      Option PCL
      1.03 or newer
      D3785913C or newer
      OpePanel.EXP_USA
      2.02 or newer
      D0145453D or newer
      OpePanel.EXP_EUR *
      2.02 or newer
      D0145454D or newer
      Language Install
      2.02 or newer
      D0145451C or newer
      Engine
      1.50:01 or newer
      D0145402J or newer
      *Note: This firmware is for the following models only: D014-26/D014-27/D014-66/D015-26/D015-27/D015-66.
      Answer
      Subject
      Symptom
      TSB#
      Cause
      Solution
      Note
      SC991
      Interrupt printing with FTP.
      Firmware History
      Network Support firmware
      Install the latest Network Support firmware.
      Ver. 7.05.1 or later.
      SC991
      Firmware History
      System/Copy firmware
      Install the latest System/Copy firmware.
      Ver. 1.04 or later.
      SC991
      Windows XP x64: Occurs with jobs submitted using the IE ftp client
      Firmware History
      Ver. 7.11 or later.
      SC991
      After recovering from the STR condition
      Firmware History
      Install System/Copy firmware
      Ver. 1.08 or later.
      To obtain the latest firmware click here
      Note: STR is a newly-added feature of the D014/D015/D078/D079 copier, which further minimizes energy consumption while the machine is in Energy Saver mode.
      Based on what the codes are for, I'm assuming the error happens when the machine goes into sleep/stand-by and when it is awakened it can't re-establish the connection with the Fiery. Does the customer do a hard shut down at the end of the day? If not this is likely the issue. I'd check your firmware levels on the machine and update them accordingly.
