super user code for MP9000
  • idplus2
    • May 2011
    • 19
    Hi everyone,
    Do someone have any super user code for MP 9000. I would like to make active the ethernet usb board on this machine.
  • rsyarcia
    Hair Straightener Tech
    • 711
    what do you want supervisor login or super user code login?
    Nobody is perfect..
    • Moza
      • 232
      This option is enabled in Service Mode SP5985 01-02
      • rsyarcia
        • 711
        you can read the security manual of the machine about the supervisor and administrator login info. (supervisor,admin)
        Nobody is perfect..
        • idplus2
          • May 2011
          • 19
          i want the super user code
          i just want the super user code
          • TonerMunkeh
            Professional Moron
            • 3865
            The super user code (if indeed there is one) won't activate the NIB. It has to be done in service mode.
            Hit it.
            • idplus2
              • May 2011
              • 19
              I suppose to enter a super user code to access the SP 5985 service code
              • rsyarcia
                • 711
                ok just wait, somebody will give you
                Nobody is perfect..
                • Mr. T
                  • May 2011
                  • 14
                  no super code is needed just go to sp 5985 set to 0 turn off machine and on board nic will be enabled
                  • Jomama46
                    • 2900
                    Where are you getting your "super" information?
                    sigpic
                    A+; Network +; PDI+
                    • rsyarcia
                      • 711
                      lol
                      Nobody is perfect..
                      • idplus2
                        • May 2011
                        • 19
                        Definitely i need it to do it. For another code like sp1xxxx, 2xxxx, 3xxxx, i dont need it but for sp5985 i need it.
                        • Jomama46
                          • 2900
                          Try this, In service mode. press and hold the # key when you press Copier Service.
                          sigpic
                          A+; Network +; PDI+
                          • knightfall
                            • Jul 2006
                            • 633
                            not even a thank you to you guys for pointing him straight. Ingrate.
                            Get your facts first, and then you can distort them as much as you please.
                            • iMind
                              Vacuum Cleaning Expert
                              • Mar 2008
                              • 1116
                              LOL, the guy killed himself with so many super user codes.....overdose
                              sigpicWe can all Win, but at the end we all loose. Save the greyhound
