MP6500 Jamming ,middle sensor
  • copyron
    • Aug 2025
    [Jamming] MP6500 Jamming ,middle sensor
    Anyone had Jams at middle sensor on Ricoh MP6500,new feed station installed,jams from all trays except bypass tray which works fine,no dev spillage anywhere.
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Co-worker had this recently, check reg clutch. His was accidently disconnected.
    • Jomama46
      • 2900
      No reg clutch on this machine. What is the jam code?
      sigpic
      A+; Network +; PDI+
      • TonerMunkeh
        Professional Moron
        • 3865
        If the copy count is over 1.5m replace the registration mylars.
        Hit it.
        • Jomama46
          • 2900
          Good call, TonerMunkeh
          sigpic
          A+; Network +; PDI+
          • TonerMunkeh
            Professional Moron
            • 3865
            ty kindly
            Hit it.
            • copyron
              copy count is only 750,000,mylars look ok.
              • ricoh-man
                • May 2011
                • 10
                Check the rubber/damper and the drive belt of the registration motor.
                • JustManuals
                  • Jan 2006
                  • 9838
                  Just Manuals | The Internet's largest selection of manuals | Instant Downloads
                  Paul@justmanuals.com
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    Have you had the registration section out to have a look at the internal mylars? They aren't visible from the outside and these are the ones that cause the problems.
                    Hit it.
                    • aabarnes1
                      • Mar 2009
                      • 620
                      Remove the letterbox type cover under the by pass and behind there is an optical sensor that is the middle sensor, Jam 11 I think, any way clean this alomg with the sensor under the dev unit,(reg sensor, gets covered in paper dust), should do the trick for you.
                      Grant me the serenity to accept the things I cannot change.
