MPC 3500 DEAD! only main powe led on
I double checked and that is the part number for the diode on the 220v PSU. Can you check the cost, it should show a low price for that part (at least in relation to the entire PSU). The part number I have listed for the EU/AA PSU is AZ24 0110 (NA is AZ24 0109). And normally yes, Ricoh wouldn't supply an individual part like this. But being that this part has a high failure, it's a lot cheaper just replace this component using the skills that a field tech has (big enough to get our fat fingers on and soldering 3 points. A smaller component or surface mount would necessitate replacing the entire power supply I'm sure).Comment
Hmm, I think there is a bit of a problem with the original Ricoh RTB that iMind quoted.
My Spare Parts Manual tells me that I need a AZ24 0110 PSU cct bd but there is a link to a Mod Bulletin, MB222055, that says that PSU has been up graded and its new number is AZ24 0150. Also the the price list says a AZ24 0150 is worth $600. No mention of a diode anywere.At least 50% of IT is a solution looking for a problem.Comment
Im a hunting a couple of the diodes as well. AZ24 0110 has been superceeded by AZ24 0150 (POWER SUPPLY UNIT:494W:EU/AA:A) on our parts list. What does ricoh descibed the diode as, might be able to find it through that."See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."Comment
Ribbon cable? Which one?It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
You're just trying to confuse meIt's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
Re: MPC 3500 DEAD! only main powe led on
Hi guys! I've been trying to bring back to life a couple of power supply boards... The old ones I mean - AZ24-0110. I've got three of those with identical fault: machine dead, blowing FU2.
So I put it on my bench a had a closer look. In all cases - main rectifier shorted, dead as a stick, as well as the diode mentioned before (YG963) and one of the PFC's MosFET transistor 2SK2915. So I did change the components and it's no longer blowing the fuse, however I can't get +24V working..The only voltage looking good is +5V, but it does have a separate switching power supply circuit. No chance to find a schematic diagram as you all probably know...
Just wondering if there's a way to get +24V up and running on a bench, out of the machine? Doesn't it need some "start" signal from the machine's controller by any chance?
Thanks in advance
KrisComment
