MPC 3500 DEAD! only main powe led on
  • teebee1234
    • 1670
    Originally posted by Lagonda
    OK, so where are you getting the diode from? The last time I checked they were not available through the electronic parts shops and the only guy I found on line was in Tiawan and he would only deal with me if I brought 10,000 of them.
    It can be ordered as a part (AZ240150). It's in the tech bulletin on the same post you quoted from iMind.
    • Lagonda
      • Aug 2008
      • 1649
      AZ24 0150 comes up in my Ricoh Dealer Parts List as a complete power supply.
      I didn't think Ricoh delt in fiddly little parts like a single diode.
      • teebee1234
        • 1670
        I double checked and that is the part number for the diode on the 220v PSU. Can you check the cost, it should show a low price for that part (at least in relation to the entire PSU). The part number I have listed for the EU/AA PSU is AZ24 0110 (NA is AZ24 0109). And normally yes, Ricoh wouldn't supply an individual part like this. But being that this part has a high failure, it's a lot cheaper just replace this component using the skills that a field tech has (big enough to get our fat fingers on and soldering 3 points. A smaller component or surface mount would necessitate replacing the entire power supply I'm sure).
        • Lagonda
          • Aug 2008
          • 1649
          #19
          Hmm, I think there is a bit of a problem with the original Ricoh RTB that iMind quoted.
          My Spare Parts Manual tells me that I need a AZ24 0110 PSU cct bd but there is a link to a Mod Bulletin, MB222055, that says that PSU has been up graded and its new number is AZ24 0150. Also the the price list says a AZ24 0150 is worth $600. No mention of a diode anywere.
          • neergish
            • 177
            #20
            Im a hunting a couple of the diodes as well. AZ24 0110 has been superceeded by AZ24 0150 (POWER SUPPLY UNIT:494W:EU/AA:A) on our parts list. What does ricoh descibed the diode as, might be able to find it through that.
            "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
            • CableGuy
              Impulse Drive Engineer
              • 417
              #21
              There is a bulletin out on this problem. What they have done if beefed up the PSU, as this is a known problem on these models. Consult your RTB's and all shall become clear.....
              • denesh
                • Mar 2011
                • 9
                #22
                check the ribbon cable
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  #23
                  Ribbon cable? Which one?
                  Hit it.
                  • denesh
                    • Mar 2011
                    • 9
                    #24
                    sorry guy, it was the mpc 2500 that i had that problem with. the ribbon cable runs from the BICU to the IOB
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      #25
                      You're just trying to confuse me
                      Hit it.
                      • denesh
                        • Mar 2011
                        • 9
                        #26
                        lol sorry dude
                        • forpaxe
                          • Oct 2010
                          • 6
                          #27
                          Re: MPC 3500 DEAD! only main powe led on
                          sorryto dig upthe topic, it is confirmedthe diagnosis ofPSU?
                          • sandmanmac
                            • 3975
                            #28
                            Yes. Wouldn't it be a refreshing change if many of those that came looking for help, would update the thread, and just maybe even show a little appreciation afterwards
                            • Gift
                              • Mar 2011
                              • 2457
                              #29
                              yap..
                              • gasior78
                                • 29
                                #30
                                Hi guys! I've been trying to bring back to life a couple of power supply boards... The old ones I mean - AZ24-0110. I've got three of those with identical fault: machine dead, blowing FU2.
                                So I put it on my bench a had a closer look. In all cases - main rectifier shorted, dead as a stick, as well as the diode mentioned before (YG963) and one of the PFC's MosFET transistor 2SK2915. So I did change the components and it's no longer blowing the fuse, however I can't get +24V working.. The only voltage looking good is +5V, but it does have a separate switching power supply circuit. No chance to find a schematic diagram as you all probably know...
                                Just wondering if there's a way to get +24V up and running on a bench, out of the machine? Doesn't it need some "start" signal from the machine's controller by any chance?
                                Thanks in advance
                                Kris
