Nashuatec 1305f sc550
  • hossam
    • Aug 2010
    • 70
    [Error Code] Nashuatec 1305f sc550
    how can i reset this code pls?
    it's said in manual:
    fusing temperature failed to drop to expected level within a given time (15seconds, 15minutes, or 25 minutes, depending on mode) after entering standby or low-power mode
    -TRIAC short
    -Fan not running
    what is TRIAC? and what fan?
    i changed fuser unit but still problem help pls
  • rsyarcia
    Hair Straightener Tech
    • 711
    Perform sc code reset(5810) from SP Mode.
    Nobody is perfect..
    • JustManuals
      • Jan 2006
      • 9838
      Oy!
      • hossam
        • Aug 2010
        • 70
        i'm done it just wanted to reset
        sp 5810 select "1" then simultaneously press the original type key and the ok (or #) key
        • hossam
          • Aug 2010
          • 70
          • RebelPhoenix
            • Oct 2008
            • 138
            You must SP-5-810 after click the 1 anfter press OK with press original type key. Machine will restart itself. After If you show this sc code again. You try the replace the PSU (Power supply unit), (TRIAC)
            And You must check the Exit fan running. Diassamble the Machine's rear cover. You must see it. If this fan isn't running machine show a sc code. I don't show the this sc code on this model. But I live a fan problem on AF-1515MF after change the parts. And machine is running
            • jummamaster
              • Mar 2009
              • 99
              good explanation
              Ricoh Error Codes
              Canon Error 5100
              Canon Error B200
              j
              c
