Stinker trouble on Ricoh AF-2045 (SC-304)
  • RebelPhoenix
    • Oct 2008
    • 138
    I have a crazy machine. This machine is Ricoh AF-2045. Charge roller bias is go up to 2000V and sometimes machine show the SC-304,
    - I replace the ID sensor,
    - I check the ID sensor connection,
    - I replace the High voltage supply board,
    - I replace the development unit,
    - I replace the drum unit,
    But trouble is continues. I am going crazy. Do you have another idea to solve the problem?
  • TonerMunkeh
    Professional Moron
    • 3865
    Next step is IO board I think. The machine must be mis-reading the ID sensor voltages.
    Hit it.
    • rsyarcia
      Hair Straightener Tech
      • 711
      the charge roller bias will go high gradually when the development roller has toner( flakes )around it or Toner is stuck on the development sleeve. When you repalced the development unit have you returned the charge roller bias to default?
      Nobody is perfect..
      • Eric1968
        • 2458
        Transfer Unit clean? Maybe it is smearing toner on the drum surface
        • RebelPhoenix
          • Oct 2008
          • 138
          Transfer unit clean and I don't show a toner on transfer belt. I ran the machine is clearly the right cover. I want to see test pattern. Pattern is show but drum surface has the excess toner same the toner smearing. I have 3 development unit. And I try the all development unit but same situation.
          • Herrmann
            • Jan 2006
            • 792
            Check if Drum Ground is ok, there is a contact at the end of the drum shaft, if i remember correctly. Also make sure, that the ereasing leds are clean and working.
            If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
            • iust
              • Jul 2008
              • 58
              its important when you replace drum or develop. unit. reset all seting to defult and executed new units in sp mode (I think this code is sp2801)
              • RebelPhoenix
                • Oct 2008
                • 138
                Queching lamp is working. Maybe I check the drum shaft.
                • aabarnes1
                  • Mar 2009
                  • 620
                  You default charge roller bias should be between -1450 and -1700 depending on your drum surface. You said that you had the right side door open to see the patch and there was toner all over the drum- this is usually a dev issue. Possibly the mag roller, the dev bias is too high also, sould be around -550v.
                  Grant me the serenity to accept the things I cannot change.
                  • RebelPhoenix
                    • Oct 2008
                    • 138
                    Development bias is 550V And Charge roller bias is 1500V but When I open a cover after close the door. Machine is self checking. After Charge roller bias is up the 2000V.
                    • NeoMatrix
                      Senior Tech.
                      • 3513
                      Try cleaning the Dev mag roller. The mag roller may be totally coated in old toner.
                      Use a scottbrite scour pad (same as you do dishes with) to clean all the old coated toner off the mag roller.
                      You may also like to check all dev unit electrical grounding points are in postion and clean.
                      There is a metal tab at the back of the dev unit that must make contact with the top of the doc blade inside dev tank.
                      • hari5
                        • Jul 2009
                        • 1
                        Re: Stinker trouble on Ricoh AF-2045 (SC-304)
                        today i'm facing this kind of problem change new drum,delevoper,cl.blade but the problem still appearing&try change id sensor,drum charger roller but no luck,last i install back old drum its ok no sc304.pls try to install back old drum and see its ok or not.
                        • vargue
                          • Oct 2011
                          • 404
                          wellcome first yo change all units of machine except thread reasone pcr primary charge roller didn't charge drum correctly this thread in 1085 is high voltage board i hope that help yo good luck
