ghost images AF3030
  • jaspiau
    • Feb 2007
    • 24
    ghost images AF3030
    Hi friends,
    This machine, AF3030, gives shadowing (Ghost images) only on the first print when the customer prints , first thing in the morning, then it is fine. I have replaced the PCU twice, all the parts in fuser has been replaced. I have seen that the charge roller bios changes from the default value of -1700 to -1650 . Is that normal?
    JASPI.
  • mikadonovan
    • May 2008
    • 2931
    I have had this problem in the past on this model, and a new PCU took care of it. Are you using rebuilds or new OEM pcu's? Also, you might try changing the setting of SP 2998-2 (reverse rotation for the drum at the end of a job). I suppose if that is turned off it could create a ghosting problem on the first copy.
    NEVER ASSUME ANYTHING
    • jaspiau
      • Feb 2007
      • 24
      Thanks Mika,
      I am using new PCU's (Part No: 411018) but they are not the original from Ricoh, outsourced from a third party. I will try the SP mode you have told me. Also one thing coming to my mind is, could it be the laser synchronizing error which may be causing this?
      Thanks.
      JASPI.
      • Eric1968
        • 2458
        Isn't this just moisture building up around the Fusing Unit when it warms up for the first time in the morning?
        The machine adjusts the Charge Roller voltage automatically to achieve the best charge on the surface of the drum. After a while the voltage will tend to rise because of the aging drum.
        • mikadonovan
          • May 2008
          • 2931
          I suppose it could be moisture, depending on the environment. He has tried new PCU's, same problem. I would tend to think any fuser moisture would dissipate in the warmup cycle. I don't know. He didn't mention ld synch errors in the original post. I'm worn out and better do this tomorrow.
          • TonerMunkeh
            Professional Moron
            • 3865
            Originally posted by jaspiau
            Thanks Mika,
            Thanks.
            JASPI.
            Try an OEM PCU first, see if that takes care of the problem.
            Hit it.
