Hello,
I've a problem with a mpc3000.
The machine print with a bad quality only picture.
text and other normal things are printed regularly.
The total counter's machine is 180.000 but color only 35.000.
3,000 copies ago, I replaced magenta drum with a modded black drum and the entire image transfer unit with a modded unit of a spc811.
Now to solve the problem I also I've replaced the black drum and black developer but the problem is not solved.
I am attaching sample image to better explain the problem.
Thanks in advance.
By.
Thanks in advance.
By.
