PCL XL error (MP 2000le)
  • Frank12
    • Nov 2008
    • 77
    Good day to all.
    Every time i print out, will print also the error message (PCL XL error Warning: ILLegaL MediaSource.) Tried to re-installed the driver still.its a waste of paper coz 1 print out 1 print out error also.
    Thanks,
    Frank
  • Mess
    Copier Gawd
    • 81
    if you are using the PCL6 driver 0r a universal driver, switch to PCL5e. Also switch to LPR port. queue name LP or print.byte count enabled.
    • leo34staffs
      copierman
      • Aug 2007
      • 503
      Print out the config page to see what drivers are enabled (some only have rcps)
      Networking skills are advantageous but use of a 3m vacuum cleaner is essential
      • TonerMunkeh
        Professional Moron
        • 3865
        Some don't even have that. I've a nasty suspicion you can only use a GDI driver on this machine.
        Hit it.
        • mikadonovan
          • May 2008
          • 2931
          On Ricoh's website it has a pcl6 and pcl5 for DDST. What is DDST? This may be a stupid question.
          NEVER ASSUME ANYTHING
          • Mess
            Copier Gawd
            • 81
            ddst is a controller type, as opposed to GW architecture
            also this pcl xl error is a known PCL6 driver issue
            • TonerMunkeh
              Professional Moron
              • 3865
              DDST is like a non-GW controller for the Stella and Kir. I think the crappier Diana's have a version of it too.
              Hit it.
              • mikadonovan
                • May 2008
                • 2931
                Been working on the B039's for years and didn't know that. Learned something new today. I guess it wasn't too stupid of a question.(My formal training on this model was being handed a manual and told "you now work on these, too")
                • mrwho
                  Major Asshole!
                  • 4299
                  I've algo got a customer with that issue printing from certain documents - the printout will come out fine but, at every printjob's end, it will print that exact same error. Since the job is unafected, it would be nice to, at least, disable that error printing.
                  I couldn't pinpoint the source yet because when I got there, the problem had been gone for a couple of days. But I suspect it will come back.
                  EDIT: It's on a MPC2051.
                  Mascan42
                  Ibid
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    Try:
                    User Tools / Printer Features / System Tab / Print Error Report to OFF.
                    Hit it.
                    • mrwho
                      Major Asshole!
                      • 4299
                      Originally posted by TonerMunkeh
                      Try:
                      Did that when I went there - it was already off.
                      Mascan42
                      Ibid
                      • rthonpm
                        • Aug 2007
                        • 2849
                        Change the driver to PCL 5 and your issue will be solved. XL drivers use a slightly different command structure which interprets perfectly good commands into something goofy.
                        • mrwho
                          Major Asshole!
                          • 4299
                          That solution isn't very appealing since it is a customer with a lot of computers - unless I suggest to replace only the affected ones. I'll try that.
                          Mascan42
                          Ibid
                          • dfs
                            • May 2011
                            • 25
                            Ive had this issue with many customer found that this was a driver setup issue. Customers IT did not setup the accessories tab correctly on the servers print cue.
                            All i had done was print out a printer config page and made sure the accessories that were attached on the MFD were the same as what was setup on the printer cue under accessories and the XL error print job did not print out.
