try cleaning the registration sensor with alchohol or mr mck, or replace it. Had a similar prob it works now.
MPC4000 intermmitent jamming at 18, 19 and 20
Serial Swop
For the couple of minutes it takes, there are only 2 screws that hold the machine exit in (one from the side above fuser and another behind the fuser exhaust fan) and check for the bushing ceasing on the decurling roller. When it happens, the page is out of the fuser and heading to the exit when it stops. What will happen is the D-shaped belt gear will crack and skip. Took us awhile to find but on certain machines we check it regularly (fly in gold mine)Kittens give Morbo gas.
A+, Network+, Server+, PDI+Comment
For the couple of minutes it takes, there are only 2 screws that hold the machine exit in (one from the side above fuser and another behind the fuser exhaust fan) and check for the bushing ceasing on the decurling roller. When it happens, the page is out of the fuser and heading to the exit when it stops. What will happen is the D-shaped belt gear will crack and skip. Took us awhile to find but on certain machines we check it regularly (fly in gold mine)the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
Another thought. There is a bulletin on the MP4000 that affects all machines with the same feed stations. They have changed a bushing in the tray for jamming out of the tray. It does work. I had my own MOD for a time before getting a proper part number for the bushing. Now you are not having the right jam codes BUT I don't always trust them. See image: Item 20 MP4000 Bulletin 51 on TSRC.
bushing.jpgKittens give Morbo gas.
steeve
The day before yesterday I replaced the 2 front door interlocks, the right door push switch and the paper feed motor.
I was there this morning and the jam counter was zero. They only ran about 1000 prints on it so it is too soon to celebrate.
I will post back if this fixes it.Comment
Re: MPC4000 intermmitent jamming at 18, 19 and 20
I would replace the door switches. Ive heard of guys having issues with them and this could be similar to what they've told me about. It may not actually flash the message or anything of that sort but it could be so quick that its undetectable. Just a cheap alternative suggestion because it sounds like you've been thru the gambit on it.Make yourself invaluable to everyone whether you're around or not.Comment
hi
im having the same problem on a relatively new machine (about 40k) the customer believes its only when doing double sided, i havent yet seen it jam but its getting 19 and 20 jam codes about 11 in a week, just wondering if there was a final solution , should i be ordering up door switches
regards
benComment
Good place to start and include the bridge interlock switches too, as mentioned by cobiraysigpic
A+; Network +; PDI+Comment
Have had this happen on a few machines as well.- Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
Fully qualified technician for Ricoh - Canon - Sharp - HP - BrotherComment
