MPC4000 intermmitent jamming at 18, 19 and 20
  • Serial Swop
    try cleaning the registration sensor with alchohol or mr mck, or replace it. Had a similar prob it works now.
    • df3036
      • 109
      For the couple of minutes it takes, there are only 2 screws that hold the machine exit in (one from the side above fuser and another behind the fuser exhaust fan) and check for the bushing ceasing on the decurling roller. When it happens, the page is out of the fuser and heading to the exit when it stops. What will happen is the D-shaped belt gear will crack and skip. Took us awhile to find but on certain machines we check it regularly (fly in gold mine)
      Kittens give Morbo gas.
      A+, Network+, Server+, PDI+
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        Now that's a useful post, thank you!!!
        • df3036
          • 109
          #19
          Another thought. There is a bulletin on the MP4000 that affects all machines with the same feed stations. They have changed a bushing in the tray for jamming out of the tray. It does work. I had my own MOD for a time before getting a proper part number for the bushing. Now you are not having the right jam codes BUT I don't always trust them. See image: Item 20 MP4000 Bulletin 51 on TSRC.
          • steeve
            #20
            mp4000 jams
            check the bridge unit switches.
            • cobiray
              • Mar 2008
              • 1199
              #21
              If it had a bridge unit (he already stated there was no bridge or finisher).... it would be throwing 001 jams with the bridge interlock issue. Also, there is a firmware update for the 001 jams due to poor contact inside the switches...
              • nick40
                • Jan 2011
                • 47
                #22
                The day before yesterday I replaced the 2 front door interlocks, the right door push switch and the paper feed motor.
                I was there this morning and the jam counter was zero. They only ran about 1000 prints on it so it is too soon to celebrate.
                I will post back if this fixes it.
                • nick40
                  • Jan 2011
                  • 47
                  #23
                  Re: MPC4000 intermmitent jamming at 18, 19 and 20
                  I was there this morning and the jam counter was zero after about 4k prints. Either paper feed motor, front door interlocks or right door push switch fixed it.
                  Thanks everyone for their replies.
                  • Andy6096
                    • Aug 2009
                    • 14
                    #24
                    I would replace the door switches. Ive heard of guys having issues with them and this could be similar to what they've told me about. It may not actually flash the message or anything of that sort but it could be so quick that its undetectable. Just a cheap alternative suggestion because it sounds like you've been thru the gambit on it.
                    Make yourself invaluable to everyone whether you're around or not.
                    • benn84
                      • Jan 2011
                      • 26
                      #25
                      hi
                      im having the same problem on a relatively new machine (about 40k) the customer believes its only when doing double sided, i havent yet seen it jam but its getting 19 and 20 jam codes about 11 in a week, just wondering if there was a final solution , should i be ordering up door switches
                      regards
                      ben
                      • Jomama46
                        • 2900
                        #26
                        Good place to start and include the bridge interlock switches too, as mentioned by cobiray
                        sigpic
                        A+; Network +; PDI+
                        • benn84
                          • Jan 2011
                          • 26
                          #27
                          It doesn't have bridge unit so will go with door switches
                          Regards
                          Ben
                          • Jomama46
                            • 2900
                            #28
                            Keep us updated
                            sigpic
                            A+; Network +; PDI+
                            • Cipher
                              It's not easy being green
                              • May 2006
                              • 1309
                              #29
                              I have had the exit section of the machine start ceasing at the decurling roller. The bushing gums up and even wears the rollers shaft. Replace the bushing and the roller and do not oil. It has been worse in dirty environments and on several machines we have.
                              Have had this happen on a few machines as well.
                              • benn84
                                • Jan 2011
                                • 26
                                #30
                                I will check that also
