SC-322 problem Ricoh aficio 2035
  • dawn
    • Mar 2011
    • 48
    [Dead] SC-322 problem Ricoh aficio 2035
    Hey guys i am a new member in this forum.
    I am asking your favor if anybody knows how to repair laser diode unit for aficio 2035?
  • TonerMunkeh
    Professional Moron
    • 3865
    Change the door switches above the fuser and next to the main power switch before you look at the laser unit. Also, change the seals on the PCU and dev unit (G065 2279 and 3066) when you do this, one will probably be split leaking toner into the front of the machine. Unfortunately, just repairing an LD won't work, you need to change the complete laser unit.
    Hit it.
    • dawn
      • Mar 2011
      • 48
      Thank you for the advice. The machine is working fine now. I have just replace the laser unit assy. So it seems laser unit assy is not repairable.
      • ccchuah
        • Mar 2009
        • 157
        solder out the two laser LED on the LD board, remove the board and clean the internal components.
        • dawn
          • Mar 2011
          • 48
          *ccchuah* thank you I will do it.
