MPC3000 with a couple of problems
  • mrwho
    Major Asshole!
    • 4299
    [Electrical] MPC3000 with a couple of problems
    I've got a Ricoh MPC3000 with a couple of problems. They don't seem to be related, but I'd like to know if any of you guys and girls ever got any of this:
    - First off the operation panel LCD backlight doesn't turn on. Customer says it's been like this for some time (it's a new customer for us) and that a different panel from a similar machine they have has been tried and the problem persisted with the other panel.
    I've checked the cablings and connectors and everything seems to be okay. I've measured all the fuses I could find on the Bicu and the Operation Panel's Inverter Board and they also measure ok.
    - Secondly the machine now gives an SC202 error - polygon motor. I'm temped to order a polygon motor, but since the polygon and the operation panel are both driven by the same board (the Bicu) it got me thinking if I could have a damaged Bicu.
    Is there any way of testing the Bicu without having to order the board? Or, at least, has anyone got a situation like this happen to him who can tell me with some certainty if it is the Bicu or something else?
    An aditional question: I could only find 2 fuses on the Bicu. Is this right or am I missing something?
    Cheers!
    Mascan42
    Ibid
  • tcs04
    FORMER Techie
    • 1183
    Could be a direct 5v or 12v line fault from the PSU
    • sharpmind
      • Sep 2009
      • 478
      I have encountered the same problem and I replaced the polygon mirror motor and BICU as a pair.
      • mrwho
        Major Asshole!
        • 4299
        Also with the lcd backlight failure?
        Mascan42
        Ibid
        • sharpmind
          • Sep 2009
          • 478
          When you press the touch panel you can hear click sound, right?When you press the ten key buttons it responds as well.The only thing is there is no backlight on the LCD screen. You can see the error code SC 202 through WIM.Is this what happened to your machine?
          What I did was I replaced both BICU and polygon motor at one time and the problem was resolved.
          • mrwho
            Major Asshole!
            • 4299
            Exactly, although I can see the 202 error on the LCD by pointing a strong flashlight at it.
            Also, did you try first to replace just the polygon and/or the bicu before replacing them both?
            Mascan42
            Ibid
            • cobiray
              Passing Duplication Xpert
              • Mar 2008
              • 1199
              How's your line voltage?
              • mrwho
                Major Asshole!
                • 4299
                If you're talking about the wall outlet, it's fine - the machine's at our shop. The symptoms are the same here as they were at the customer's.
                Mascan42
                Ibid
                • Herrmann
                  • Jan 2006
                  • 792
                  Try to disconnect the Polygon Motor and see what happens, does it bring the backlight back on?
                  If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                  • mrwho
                    Major Asshole!
                    • 4299
                    Nice thought, I'll try that as I get the chance!
                    Mascan42
                    Ibid
                    • sharpmind
                      • Sep 2009
                      • 478
                      I had disconnected the connectors in the laser unit but same problem.I had tried to replace the polygon mirror motor using old BICU but no luck.I never tried to replace the BICU using the old polygon motor because when the polygon motor is shorted it damages the BICU.Replace them both to be sure.
                      • carlosp
                        Re: MPC3000 with a couple of problems
                        was this ever resolved? I have the exact same problem. Any help would be much appreciated.
                        • ragajungle
                          Polygon Motor error - check for pinched wire in laser unit harness behind fax option ( if installed )
                          Polygon Motor error - replace BICU if CN520 has no trigger on pin 3
                          Polygon Motor error - replace Polygon Mirror Motor
                          The Bicu board flakes and causes all sorts of issues....
                          Make sure you post back with the result.
                          • lupi
                            • Aug 2011
                            • 102
                            sc202
                            [Cause]
                            The polygonal mirror motor controller board is faulty.
                            The IC's Q1 on the polygonal mirror motor control board is burnt.
                            [Resolution]
                            Replace the polygonal mirror motor control board
                            • mrwho
                              Major Asshole!
                              • 4299
                              I never gave any feedback as that machine got out of my hands onto a colleague's. But I believe the problem was solved by replacing both the BICU and the Polygon motor.
                              Mascan42
                              Ibid
