paper jamming in the fuser unit (model 2035)
  • akbareshghi
    • Sep 2010
    • 261
    what cause of this jamming
    the place of jamming is displayed on the below picture
    thanks for solutions suggested from friends
    Color printing with lowest cost per page is my love.
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Damaged separators, worn fuser rollers, sticky exit solenoid. More details like the jam codes your getting would be helpful.
    • cobiray
      • Mar 2008
      • 1199
      Worn or damaged separators or sticking exit solenoid. More information would be helpful, like jam codes.
      • rthonpm
        • Aug 2007
        • 2859
        Have to agree with cobiray: probably bad separators (fingers). They tend to lose their tensioner springs which causes them to just sit in the paper path. The centre one is the most notorious for this. If your users don't use SEF paper in the trays you may be able to do without it.
        • CrapAimer
          • 296
          Pressure roller worn used to cause paper jamming problems on these pieces of S--t
          • Zeldaman
            • Mar 2011
            • 946
            • akbareshghi
              • Sep 2010
              • 261
              do the one in the middle not is separator that difficult to replace with springs
              my machine have only 6 separators and i can not to installed the one in the middle
              • jonezy999
                just one copy??
                • Feb 2010
                • 952
                Sorry but, what?
                I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
                • neergish
                  • 177
                  See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier.
                  "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
                  • cobiray
                    • Mar 2008
                    • 1199
                    If that's not a signature worthy quote, I don't know what is.
                    • mdtrinh
                      • Aug 2010
                      • 68
                      Turn the knob to rotate the fuser rollers for checking any flat area on the pressure roller.
                      It happen when multiple copies are making and the pressure roller end up to replaced.
                      Hope this help.
