af 3045 adf jammed
  • adween
    • Jun 2011
    • 23
    [Jamming] af 3045 adf jammed
    i have 1 unit aficio 3045. the ADF unit will jammed when i make ADF free run. 1st page ok and 2nd page will jammed. i use both stamp mode and duplex mode also jammed.. but when i run feeder for normal copy ok. use single side and duplex also no problem.. only when use adf free run paper will jammed inside feeder.. have any idea to solve this problem?
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    The ADF free run can be a little hit and miss on various Ricoh models (I try not to use it if I can).
    Many times I've had to cycle the power off / on to fix jamming issues after using ADF free run.
