only Rear side of 2035 s dirty
  • akbareshghi
    • Sep 2010
    • 261
    my rear side of Copies is dirty but the Up side of it have good quality
    what cause(s) have created this problem
    my quesses is follwing:
    the blade of Transfer Belt cannot clean well the Transfer belt
    the Hot roller of fuser must be replaced
    the cleaning of fuser have become dirty
    etc
    but this problem have disappeared when the Hopper of toner supply is removed from machine
    thank you
    Color printing with lowest cost per page is my love.
  • Serial Swop
    Yes a good idea would be to check the tranfer section, what is weird is the removal of the hopper unit, but you might want to replace the dev filter on dev tank, this causes contamination through the m\c and builds up on the transfer even after the blade has cleaned the belt.
    • teebee1234
      • Jul 2008
      • 1670
      The mag roll being filmed over will cause this. It's not always consistently dirty across the entire copy when this happens. Remove the developer powder, scrub the mag roll clean and replace with fresh developer.
      • akbareshghi
        • Sep 2010
        • 261
        with what i must scrub mag roller of Dev unit ? which are the best your suggestion for doing this action ?
