MPC 6501
  • Serial Swop
    • Aug 2025
    [Error Code] MPC 6501
    Hi all,,, I have an MPC 6501 giving me all sorts of codes, first code is 569 pressure roller lift motor error, I have replaced the lift motor and sensor. 2nd code 570 dev unit cooling fan error which has been replaced, now i have a 547 code directing me to the AC driver board, ive also had to replace the the lamps on the fusing unit.
    all advice welcome
    thanks
  • wfinn
    • Mar 2011
    • 70
    Sounds like a board problem. Have you tried the BCU?
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from http://www.justmanuals.com
      Paul@justmanuals.com
      • Jomama46
        • 2900
        Install a quality line filter on the AC line.
        sigpic
        A+; Network +; PDI+
        • Incredible1
          • 24
          really!
          don't mean to cause any harm however is this ad/response to a question always necessary???
          • cobiray
            Passing Duplication Xpert
            • Mar 2008
            • 1199
            x2. Check your wall voltage, as well as ground/neutral voltage.
