Ricoh 2238c
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Ricoh 2238c
    Hi Guys,
    I have a strange problem on this machine (printing and copying) where when i do a colour print the trailing edge has a band (approx 5mm to 10mm) of black on one page , then yellow on the next, cyan on the next and ...magenta on the next. Unfortunately i have no samples to show, but any ideas as im stumped!!
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from http://www.justmanuals.com
    Paul@justmanuals.com
    • rthonpm
      • Aug 2007
      • 2859
      Sounds like a residual image from the line position. Make sure all of your paper guides are good, and that the users aren't putting used paper in the machine (just in case).
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        You might need to replace your transfer belt cleaning blade.
        • leo34staffs
          copierman
          • Aug 2007
          • 503
          Its a solid band, and appears on the trailing edge, it seems like it has been written there, not from lack of cleaning, the id sensor result is 010101 so cleaning should be good.
          Its very strange that its a different colour solid band on each copy.
          • leo34staffs
            copierman
            • Aug 2007
            • 503
            20110622093134417_0002.jpgHere are some samples:20110622093134417_0001.jpg
            • bjakobs
              • Mar 2010
              • 25
              I ran across the exact same thing a couple of years ago, but seem to recall it was only when printing, and it was caused by a paper format mismatch or at least a driver issue. You sure this also happens when copying?
              • Fearless V K
                • 620
                upload nvram to sd card. perform memory clear. download nvram from sd card.
                Don't take that toner with me!
                • leo34staffs
                  copierman
                  • Aug 2007
                  • 503
                  I have swopped over the whole controller assy with another nvram and the same fault occured!!
                  • leo34staffs
                    copierman
                    • Aug 2007
                    • 503
                    Re: Ricoh 2238c
                    Update! The problem was fixed by replacing the bicu board (the one where the laser plugs into) Thanks for the suggestions.
                    • Jomama46
                      • 2900
                      Re: Ricoh 2238c
                      Thanks for the feedback Leo, this was a weird one.
                      sigpic
                      A+; Network +; PDI+
