J007 error in ARDF (MP 5000B)
  • sharpmind
    • Sep 2009
    • 478
    Guys, I have MP 5000B which jams constantly in document feeder.The leading edge of the paper always stop in the strip glass area and throws jam error J007. I have already cleaned all the sensors I know in the document feeder but still paper jams.Done output check and all mechanisms in the feeder are ok.
    Have any idea on this problem?Any insights is highly appreciated.
  • Jomama46
    • 2900
    There is a little "well" on the top of the df that aligns with the sep sensor. It gets paper dust in it and it causes false readings. Blow it out.
    sigpic
    A+; Network +; PDI+
    • sharpmind
      • Sep 2009
      • 478
      Thanks for the quick reply.IN fact, I've already done it.My apology if I did not tell that in my previous thread.Do you think one of the sensors fail and needs replacement?
      • Jomama46
        • 2900
        when you say "constantly" you mean, it Never works or you get a call every day? 007 means the paper doesnt get to the inverter sensor which is a long way from the scan glass, where I understand the paper is stopping. If so, then inverter sensor is not at fault. Maybe a one-way is failing.
        sigpic
        A+; Network +; PDI+
        • sharpmind
          • Sep 2009
          • 478
          The document feeder is not working in any ways. Can you tell me which "one way"are you referring?
          • Jomama46
            • 2900
            Here's where I would start
            sigpic
            A+; Network +; PDI+
            • sharpmind
              • Sep 2009
              • 478
              Thanks bro! I"ll check it.
