Hi all
I have a problem with a clients scan to folder setup I hope someone can confirm my thoughts with:
They are unable to scan to folder. .....
They worked fine until a recent server fault and faulty network switch.
I have attended site to check the scan settings.
When trying to browse their network using the 'manual' scan feature on the copier control panel, I cannot seem to connect to anything, browse their network neither by server IP address nor Server name.
I have connected my laptop straight to the NIC on the copier with a cross over cable (excluding their network) and setup scan to folder easily with no problems. . . .
My question is this, is there any setting on the copier which can block the copier from gaining access to their network?
I have connected my laptop to their network and CAN browse and succesfully transfer a file to and from the network share.
Everything points to their network and originally suspected they provided incorrect user name and password credentials, however I CAN access the server and network share with the provided credentials through my laptop?!!!!
I'm sure its a simple fault on their network but as I can access their network share on their server with my laptop and provided credentials, they automatically assume its a copier fault, yet I can setup scan to folder with the cross over cable to my laptop. . .
Their server is Windows small business server 2008.
I look forward to your experience with these kind of situations!
John
John
