User Code Authentication
  • Copier Doc
    • Mar 2010
    • 49
    Having just installed an MPC5501 into a school with 100 user codes/pin numbers setup for copy/print authentication, can anyone tell me if it is possible to have a prompt pop up to ask you to enter the appropriate code on the print driver without having to go through the preferences menu 1st?. The machine has replaced Sharp MX5500 which had a tick box enabled that then displayed a box to allow user to enter their code each time they went to print. Cant find anything similar on the Ricoh. Suggestions appreciated as always guys.
    Thanks in advance
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Try the PCL editor or for a simpler solution just try adding the codes to the valid access tab in printing preferences so you don't have to type it in every time. This won't be a viable solution if they share PC's.
    • Copier Doc
      • Mar 2010
      • 49
      Appreciate the reply, but unfortunatley the users do all share pc's so i need (if possible) a way to ask for authentication EVERY time a print job is sent so that it can be billed appropriatly. I have looked through both PCL 5 & 6 drivers but to no avail.
      • cobiray
        • Mar 2008
        • 1199
        The first recommendation was the PCL editor. I believe it is downloadable from the drivers section of the public Ricoh family sites.
        • jonhiker
          • 661
          Printer Driver Editor
          good answer. i have installed this a few times. when the user clicks on print, a dialogue box pops up and askes for the user code. it can be installed on a server or on individual workstations.
          • cobiray
            • Mar 2008
            • 1199
            I should ad that you have to edit the driver BEFORE you install it. So if you've already installed it on a server and deployed it, you will need to do it again after you edit the driver. It's different than the old PCL editor that you edited after installation.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              It's also worth noting that the editor only works on the PCL6 driver.
              It's clearly noted on the download page, but who actually reads that stuff, right?
              BTW... It also works on my personal favorite, the universal PCL6 driver.
              • Copier Doc
                • Mar 2010
                • 49
                Just a quick note to say thanks to Cobiray for the link, I had not heard of PCL Editor before & i have to say it works a treat.
                Thanks to jonhiker & ken for your input also.
                Regards
                Kev.
