Ricoh aficio spc231n service mode
  • TecnocopyVI
    • 45
    Hi guys, what is the combine of button for enter in Service Mode in RICOH SPC231n? Thank you
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      It's the same as all the other Ricoh family machines.
      • TecnocopyVI
        • 45
        Re: Ricoh aficio spc231n service mode
        i haven't the button and number there is only stop/start,job reset,menu,escape,down,up and enter .
        What i push?
        • rthonpm
          • Aug 2007
          • 2859
          You can download the Smart Organising Monitor to access most of the service menus. I think this may also be built into the PCL driver for this model as well.
          • TecnocopyVI
            • 45
            my problem is SC543 i want reset this sc i have change fuser but SC 543 always!
            • Cipher
              It's not easy being green
              • May 2006
              • 1309
              SOM > User tools > Printer Configuration > (enter the default service access code for this model range) > SP Mode 2 > Fuser SC Reset.
              The print driver does need to be installed and the USB/TCPIP port configured correctly.
              The SOM utility uses the print driver to send it's commands to the printer.
              • teebee1234
                • Jul 2008
                • 1670
                FYI, the default service access code is "Admin074"
                • TecnocopyVI
                  • 45
                  Spc 231n don't have service mode? Only som?
                  • zed255
                    How'd ya manage that?
                    • 1024
                    Correct, access to the printer's service mode is via Smart Organizing Monitor (SOM). There is no display on the printer to see what you are doing. I had this a fuser error on one of these and didn't have the software. I had to do a little war driving to find an open wi-fi connection and download it (the customer's IT had disabled any ability to download files). It is a pain, but there isn't any other option for the printer. The MFP can be accessed the usual way as it has a keypad and display.
                    • rich2764
                      • Jun 2009
                      • 20
                      Hold down start/stop and escape, power on the printer. Continue to hold down for 10 or more seconds.
                      • laitang
                        • Nov 2012
                        • 627
                        To enter SP mode from the operation panel, do the following:
                        1/ Press both the Start/Stop key and the Escape key, and turn on the printer.
                        2/ Keep pressing these keys for more than 10 seconds, then you can access SP mode
                        • rich2764
                          • Jun 2009
                          • 20
                          Hello? Did my previous post not just say that or am I just imagining it?
                          Also you need to run SOM if you have a fuser code as it wont let you access SP mode.
                          You need a USB cable and the login required is Admin074 to access SP mode 2.
