Ricoh MPC2500
  • GeorgeBest
    • Jul 2009
    • 524
    Ricoh MPC2500
    This customer complains that scanned documents are not printed 1:1. When printing the document is slightly reduced.
    I've tried this with several machines and always get a slight reduction when scanned documents are printed immediately.Is there a setting or adjustment possible to solve this.
    Thanks in advance
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    No, it will always be slightly reduced.
    Reason being that you won't get lines from the edges of the originals.
    This has come up numerous times in the past.
    • Fearless V K
      • 620
      adjust the scaling setting in the print driver.
      Don't take that toner with me!
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        That normally works, but I've had customers who put the scans onto a web page, and they didn't line up correctly; for them it was a major issue.
        • NeoMatrix
          Senior Tech.
          • 3513
          1. Press <Scanner> button on front panel.
          2. Press <Scan settings> {Hint it's above Auto density}
          3. Press <Edit tab>
          4. Press <Erase border>
          5. Press <Same-width> or <Different-width>
          6. Press <+/-> to increase/reduce border erasing.
          You can then increase/decrease your scan page size compensate for page boarder showing.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            3. Press <Edit tab>
            That only adjusts the amount of image deletion; it has no effect on the overall reduction issue.
