SC860 hard drive error
  • kayjaig
    • 144
    [Error Code] SC860 hard drive error
    MPC3500 stay on waiting for ever. After disconnected one of the hard drive SC860 pops. Do i have to replace both hard drives or just the bad one? If so, do i have to format it after installed? Please help. thanks.
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
    • seansbar
      • Dec 2010
      • 198
      I always replace as a pair, they need to be a matched set. Anyhow, they probably are the same age, so the second one will fail shortly
      • kayjaig
        • 144
        i replaced both as suggested.
        • Gift
          • Mar 2011
          • 2457
          Usually the HDD aren't broken so reformatting should be enough - in case it took ages to detect the error it might be better to swap the drives though.
          get bent and place your ads via official banners on copytechnet
          • mansur
            Re: SC860 hard drive error
            hi all
            i just got the same problem . After formatting both hdd found that one is faulty . i inserts the good one , i still got the error sc 860. Now the hdd is 40GB IDE. Can i insert another one 320GB IDE as there is no 40 gb avalable or i need both 320GB IDE ? or it there any solution ??
            thank
            Man
