scan twain problem with 2035
+ More Options
Posts
  • akbareshghi
    • Sep 2010
    • 261
    [Misc] scan twain problem with 2035
    i donot change any driver my twain ver 3 of 2035 and before all things go well but
    i can not now scan
    the error following appeared in the computer software
    error no . -88
    DG DAT MSG iut of expected sequence
    please help me
    Color printing with lowest cost per page is my love.
  • Herrmann
    • Jan 2006
    • 792
    the newest Driver is 3.79, try to install it and see, what happens
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • akbareshghi
      • Sep 2010
      • 261
      I install 3.79 and the same error was appeared
      12320:
      Cannot find the scanner
      check if the scanner main power in on
      i guess i must perform 5801 to clear scanner data or ram of my machine
      please help me
      • adween
        • Jun 2011
        • 23
        sometimes the problem happen because of anti virus firewall. try to disable your antivirus firewall. and unblock the twain program.
        • locicsaba
          • Mar 2010
          • 2
          Check firewall and ports (1021,1022,1023,1024)
          • akbareshghi
            • Sep 2010
            • 261
            Re: scan twain problem with 2035
            i set the inteface to Ip 192.168.1.3 and subnet 255.255.255.0 and gateway to 000.000.000.000 and dns to 000.000.000.000
            when i want to scan with my program , the nod32 firewall display the following message:
            Application:Hypersnap
            remote computer: 255.255.255.255
            UDP 161(snmp)
            and after i allow this connection the following message is appeared :
            i can not now scan
            error no . -88
            please help me
            • akbareshghi
              • Sep 2010
              • 261
              How to check these port in the nod32 Firewall
              thanks
              • dawn
                • Mar 2011
                • 48
                Add the port 1022 for firewall exception.
                Go to control panel then firewall then exception then add port which is 1022. Hope it will solve your problem
                • trc
                  • Jan 2007
                  • 95
                  also check your windows version....if xp sp3, vista or 7 ........scanner firmware update first will be the best option
                  • akbareshghi
                    • Sep 2010
                    • 261
                    how to Update firmware of scanner ?
                    • akbareshghi
                      • Sep 2010
                      • 261
                      i installed scan router and after that the setting of my scanner is changed and i can not scan anyway(i try the correct firewall setting but my problem is not solved)
                      also i installed PageScopeDataAdministrator for Konica minolta C450 scanning software and perhaps this program have changed my setting of Scanner of 2035
                      because after uninstalling this program , my scanner go to failure
                      please guide me about restoring to the default setting
                      if you know troubleshooting this problem , please explain exactly, if not , please say my problem to the full-expert technician.
                      • Jomama46
                        • 2900
                        Didnt change to a 64bit OS did you? Wont work with TWAIN
                        sigpic
                        A+; Network +; PDI+
                        • akbareshghi
                          • Sep 2010
                          • 261
                          No i used windows 32 bit
