RICOH 2022
  • MGUNGU
    • May 2008
    • 12
    RICOH 2022
    Guys,i have got a ricoh 2022 ,everytime i pu a new PCU( type 1027),after btwn 5k-10k copies the drum gets worn out ie dots on copies like it has done its life timewhich is between 60k-90k copies,
    Any help out there?
  • ucinn
    • Jun 2009
    • 383
    I usually get life out of these drums. Are they using generic toner?
    • sandmanmac
      • 3983
      I agree, they generally run beyond the 60k stated life cycle - check toner
      • Eric1968
        • 2458
        If you use the original toner, these PCU's run way beyond 60k.
        • Jomama46
          • 2900
          Dots can also mean a lack of circulation in the drum area, causing arcning. Make sure fans and filters are clean.
          sigpic
          A+; Network +; PDI+
          • Megato
            • Sep 2009
            • 13
            What about the transfer roller??
            • MGUNGU
              • May 2008
              • 12
              Re: RICOH 2022
              changed the transfer roller before but it never changed anything
              • MGUNGU
                • May 2008
                • 12
                Re: RICOH 2022
                will check and clean the fans and will keep you posted
