Aficio 1060 Bates stamping
  • luig
    • Sep 2007
    • 52
    Hi, I have a customer that loves there 1060, and wants to add Bates stamping to it, for their work flow. I searched through the Ricoh TSC website and haven't found the program to download for this model. I appreciate any help or push in the right direction. Thank you in advance.
    Luig
  • tonyd
    hi
    planetpress?
    • luig
      • Sep 2007
      • 52
      That might work good for printing, but not for my customer that is running copy jobs only.
      • unisys12
        • 489
        Not real sure about the 1060 (2560 Savin), but I know the newer models such as the Savin 8055 have Bates Stamping Standard. You just have to cut it on.
        As far as I know, you can't actually download it, as a program, and install it. Your customer may be left with upgrading their machine (great opportunity for your company) or your company trying to sell them a new solution (such as Ecopy, very expensive!) for an old machine.
        sigpic
        The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
        • leo34staffs
          copierman
          • Aug 2007
          • 503
          IPRO Copy+ (i have read that does it from ricoh) on the 1060
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            I believe there is a firmware to load on this model for Bates stamp
            Mystic Crystal Revelations
            • fausto1981
              IT Technician
              • Dec 2007
              • 145
              E-Copy would be a great solution.
              but after the Firmware upgrade you can try the following:
              ((Not really sure if it applies to the machine that you are working on))
              ENABLING THE BATES STAMP FEATURE:
              1. Turn on SP 5-227-200
              1
              2. Check the setting of SP5-227-201
              3. Check the setting of SP5-227-202
              0: excess zeros displayed (Factory Setting)
              1: no excess zeros
              USING THE BATES STAMP FEATURE:
              1. In Copier Mode, press [Edit / Stamp].
              2. Press [Stamp]
              3. Press [ Stamp Text].
              4. Setting up Bates Stamping requires setting up components:
              a. <Text > b. <Numbering from / to >
              5. In <TextChange Text
              6. Type in text component (you can include spaces if required).
              7. Select [ Ok].
              8. In <Numbering from / to> field, select [Change Start No.].
              9. Type in the number that you want to begin from.
              10. Select [ #].
              11. Select [Ok].
              12. To change the position of the stamp on the printed page, select [Change] and select the appropriate location. The position shown here is the upper right hand corner.
              13. Press the [Start] button to begin the job.
              Notes:
              Bates Stamping can only be used in copy mode.
              Bates Stamping cannot be used for files saved in the Document Server.
              The location of this stamp may be positioned in the following areas: lower right; lower left; upper right;upper left and middle.
