Dirty innards 9001,8001,7001
  • BLADE
    former propeller tester
    • 478
    I have several of these models in my patch. They seem to run dirty with toner dust blowing around and also some have low print density. It appears the developer needs changing after about 200k. Most of these machines replaced mp7500s which ran ok. Anyone else seeing this? cheers
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Dirty innards 9001,8001,7001
    You using OEM toner?
    Hit it.
    • BLADE
      • 478
      yeh, yours are going ok obviously, hmm
      • TonerMunkeh
        Professional Moron
        • 3865
        Yeah, I've not seen any running overly dirty.
        Hit it.
        • rthonpm
          • Aug 2007
          • 2859
          I had a couple of 2060 and 6000s with copy quality issues that were caused by bad voltage from the wall. You may want to make sure you're getting the right amount of juice to the machine. Also, are the machines running within spec for volume? Some of the older family members always had issues with low volume.
          • BLADE
            • 478
            went to one yesterday and seems it may be leaking from hopper and drifting through machine. thing is they been doing it from new, ( like the 1600s/2000s do ... conspiracy theory ). may have to reverse the fan
            • jaredfmn
              • Sep 2008
              • 25
              change sp2966 from "24" to "4" whats happening with these new machines is the process control is too precise and not able to check correctly. change this Sp and it should change your life. It fixed at least 10 of my machines from 40k on developer back to 350k life. also change developer before you change this one more time. Good luck
              • BLADE
                • 478
                Ok, I went to what was my dirtiest 9001 (had toner dust on the scanner mirrors at first service lol) because it was running pale on long runs (toner depletion) and changed sp2209 , sp2210 , sp2506 to increase toner supply and it now runs cleaner. Control interval seems to be the fix then. Thanks heaps.
                @rthonpm - going on the lengthy warmup of the 9001 it does fit the 'older family' category
                • BLADE
                  • 478
                  just seen a bulletin for this rd062060
