Good Morning
I have a customer with a Ricoh Aficio MP6000 Copier thats was wondering if we would take a peek at it (we take care of their canon copiers and they're getting no satifaction from their current ricoh service company). From what I immediately have seen the status indicator is red and i cant get the network connection online. Im guessing its a bad network card but want to be sure. Is there a way to disable it? I've tried disconnecting it to try and isolate the problem but that prevents the machine from booting up. The confusing part (to me) is the whole machine is inoperable. The brands that we normally work on allow the other functions to be used even when there is a connectivity issue. Is this normal on Ricohs or should i be digging deeper. Everything seems fine. The machine starts up, goes through all its warm up process but status indicator never turns green but there is no error code either. When I press the print function I noticed it offline and cant get it back online. Thanks in advance.
