Ricoh MPC2050
  • GeorgeBest
    • Jul 2009
    • 526
    Ricoh MPC2050
    Machine had an SC573 error. First I cleaned the thermistors. Thought I had it repaired. Machine dit start up, no errors. And so I went.
    Next, 10 minutes later I was called back by the customer. Error SC565 on display !!!
    Cleaned again, even placed new heaterlamps !
    Still, error comes back, despite resetting and cleaning.
    Someone a clue here ?
    Thanks in advance
  • Eric1968
    • 2458
    Re: Ricoh MPC2050
    Since you did not replace the pressure roller thermistors, I would suggest to replace them (AW10 0127, AW10 0128). There's always time to replace the real expensive parts like PSU and BICU
    • jonhiker
      • 661
      Re: Ricoh MPC2050
      X2
      The SC573 is the end pressure roller thermistor and the SC565 is the preesure roller fusing lamp. If the thermistors don't take care of the issue, then the manula cals for the PSU.
      • tcs04
        FORMER Techie
        • 1183
        Re: Ricoh MPC2050
        Originally posted by jonhiker
        X2
        In these situations the thermistor is normally bent causing an overheat which blows the themostats, so you get an overheat code followed by an underheat code. change thermostats as well as thermistors. I would also load the latest firmware.
