Have not had to much experience with this printer but I have had numerous color drum units fail before their 13,000 copy life span. Usually what I see is color dropping out in stripes such as gunk building up causing the metering blade to completely wipe the toner off the DV roller. Took one unit home for S&G and took it apart. Seems as thought the DV roller is damaged because cleaning out the DV unit and recharging it does not help.
Any suggestions on how to keep this from happening?
