Ricoh Aficio 1018 error SC544
  • Marko Rkoma
    • Aug 2025
    [Error Code] Ricoh Aficio 1018 error SC544
    I got this error on Aficio 1018. Error is SC544, I checked thermistor, thermostat and thermo fuse.
    They are ok. Fusing lamp is ok too. When I try to reset this code it gives me error, so it cant be reset.
    Maybe the power board is defective?
    Does enyone know what to do? Thanks in advance.
  • fritzyas
    • Jul 2011
    • 73
    Re: Ricoh Aficio 1018 error SC544
    try replacing the thermistor/thermostat first.
    • londonboy
      • Jul 2011
      • 10
      Defo replace thermistors 1st, as are so intermittent, then reset,
      • mikadonovan
        • May 2008
        • 2931
        You can check and see if the thermistor is functioning in sp modes under FEED>fusing temperature display. By the way, I think you have to use sp 5810 and a specific procedure to reset a fuser code. Check the manual.
        NEVER ASSUME ANYTHING
        • Eric1968
          • 2458
          To reset a fuser sc, go to SP5-810, hold down the Halftone key and press OK. If you don't press the Halftone button you will get an error.
          • Marko Rkoma
            Thank you all.
            It was the main powerboard. I placed a used one from another same copier
            and now ewerything works fine.
            • mikadonovan
              • May 2008
              • 2931
              Glad you got her fixed. Thanks for the update.
