RICOH AFICIO 3260C
  • johnsonisaacnigltd
    • Mar 2011
    • 32
    RICOH AFICIO 3260C
    Can anyone help me with this copier ricoh aficio 3260c new machine, once i power on the machine work fine and shows ready but once you make any copy, it won't work cause the heater part not hot and not showing any code so i don't know what the problem might be if anybody knows what the problem please help me out
    thx
  • Jomama46
    • 2900
    Re: RICOH AFICIO 3260C
    Replace the thermistors (2) and the temp sensor. Other wise you may be looking at a board
    sigpic
    A+; Network +; PDI+
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
      Paul@justmanuals.com
      • turbojetboy
        • Aug 2009
        • 279
        thx
        That doesnt sound right, if the fuser has any sort of heating problem it will cause an error that cant be released - Unless someone before you has turned off SC detection - in which case you are probably in a hole new world of pain.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          This machine is anything but new - as I recall it came out in 2005.
          That means it has had 6+ years for anything bad to happen to it.
          • Ianizer
            • Jul 2011
            • 380
            thx
            May I ask, what is leading you to believe it is not working because the heater part is not hot?
            -I
            My name Peggy.
            You got problem?
              • Mar 2011
              • 32
              "Yes, you are right I got the machine 2007 but since then it hasn't been used, just left it in the box till last month ready to use i
                • Mar 2011
                • 32
                "What is leading me to believe, is that once the machine is on, on the screen shows ready but when you make copy then machine will scan but copy won't come out and if you open the machine and check heating part is not hot."
                • Polo-022
                  • Sep 2007
                  • 486
                  Upgrade the engine firmware, first thing you have to do before troubleshooting, since the copier left so many years unused...
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    How in the world can a $20k+ machine "just sit" unused for so many years?
                    I thought that only the US government did that.
                    • teebee1234
                      • Jul 2008
                      • 1670
                      What specifically is the problem? Does it make a print? Is it blank? Unfused? Am I getting warmer/colder?
                      • Jomama46
                        • 2900
                        Left in a box for 4 years. this has got to be an interesting story/
                        sigpic
                        A+; Network +; PDI+
                        • ragajungle
                          You need to verify that the thermistors are working correctly.
                          Enter service mode>Clr Modes> 107>clear/stop
                          Select Copy SP
                          i think it is SP1106 to display the actual temps...
                          i think SP1105 is where you can adjust fusing temps...
                          • techsass
                            • Dec 2010
                            • 248
                            New & fresh out of the box, but she doesn't work???
                            I'm guessing you're pretty tech savvy since you had to remove & disassemble the PCU's to replace the dummy DV cartridges, remove the ITB retaining rod, initialize the PCU's, etc. so help us out a little bit more - we can't see (or hear) the copier.
                            After the initial Please Wait screen, does it go thru another Please Wait phase or is it an instant Ready? Do you ever hear any motors running? Does the start key turn green again after you scan your originals? Did Sp3811 & Sp2111 complete successfully?
                            Very Strange.
                              • Mar 2011
                              • 32
                              Very Strange.
                              When I took it out of box, I only put toner cartridges and toner developers, but cause she was sitting for very long time maybe that could be the problem, once I put on the machine "please wait" then after go to ready instant, no motors running, but the start key turn green and I could scan originals.
                              thx a lot
