Ricoh MP1600 can't print on Vista,Help me.
  • ifback
    • Feb 2006
    • 52
    Hi everybody,
    i have problem with MP1600 which can't print on Vista.
    i got new driver on website Ricoh for installing this driver,everything is ok.
    but when i print, had icon printer appear but can't
    i dont know why,
    Plz Help me...
    thank a lot.
    Welcome to VietNam..
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Have you tried changing the TCP/IP port number to '10001' or is printing via USB?
    • fausto1981
      IT Technician
      • Dec 2007
      • 145
      IFBACK, I need more info to help you...
      -How is the machine connected the PC? USB, Bluetooth, Wireless, Ethernet, parallel?
      -is it installed locally or on the network?
      If on the network
      -did you put a static IP on the machine?? or its getting it from a DHCP server???
      - you mentioned that you downloaded the drivers from the website. the ones for Vista are usually all together in a mini driver.
      -can you ping the machine??? if yes, can you log in using the web image monitor ((you know go to a web browser and type the IP or the hostname of the copier))
      you might have the port configured for LPR and not RAW. or maybe using a different port number.
      if you have RAW make sure you are using port 9100
      Let me know if this helps. or answer some of the questions
      • ifback
        • Feb 2006
        • 52
        thank Daz and fausto1981
        i was printting via USB.
        • Cipher
          • May 2006
          • 1309
          Which model do you have though? the MP1600 or the MP1600L?
          The MP1600 uses a GW controller and has RPCS/PCL Vista drivers available now.
          But the MP1600L uses a cheaper low budget GDI controller and uses a DDST driver which has not any Vista drivers yet (they are due out Q1 2008).
          Apart from that printing via USB should be 'plug and play(pray)'.
          You would just need to point to the driver .inf when it asks.
          (Windows would automatically setup a virtual 'USB001' port).
          • ifback
            • Feb 2006
            • 52
            THank DaZ, Yes i installed it,ok.But when i can't print. I dont know why .
            • Scott_Lewis
              • Mar 2007
              • 519
              I do not know if you have this working now.
              Can you print to this MP1600 from Windows XP on another computer?
              • Cipher
                • May 2006
                • 1309
                Based of the information I have to go on that makes two of us then LOL.
                DaZ goes into general troubleshooting mode.
                You have checked the printer is 'online' and there is no USB device conflicts shown in the device manager in windows?
                Do the print jobs show up in the print spool when they are sent to the printer?
